1450hp Blown Alcohol Dragboat Trade for 4-5 Seat Sandrail!
BOAT WORTH $25K
Looking for Sale. Or Trade for ENCLOSED Sand car or Prerunner must be enclosed front w windshield
No vw's or trucks not interested had those!!!!! OR 1960-1972 Chevelle's , Camaro's,Nova's,GTO's etc
Will work on price!! Make offer this boat is Bad a$$ guaranteed fastest on river!!! Do you have what it takes to hang on?
1976 cole tr1 step deck
1450hp 8000RPM
Torque 5000rpm-7000rpm=950FP
Estimated by prostreet terrerists in LaHabra Spec'ed
New engine specs-chevy 468 stroker 30over
cyl bore 4.280"
-SRP Pistons 4.280bore (26 cc dome so it will be 10.5 to one on a 118 cc chamber.Heads) part number with srp is 212142 (tops
need machining)
-JE Pistons and rings
1piston and ring set(piston 212142)$94.04 (rings j100f1-4280-5)$24.26 (JE straight wall pin 990-2930-15-52s)$13
-7piston ring sets (j100f1-4280-5)$169.82
-Eagle H-Beam 6.358 connecting rods(ESP-63853DL19)$529.19
-Connecting rod bearings(Clevite Engine Parts CB743HN - Clevite H-Series Rod Bearings)$111.76
-HTD Blower pullys engine 58, blower 44 =to 31.9%overdriven
20lb Boost
-Lunati Blower cam #50207 use that number on website for spec card-Drag race camshaft mech roller Tappet, rpm 4400-8200 adv.Dur. 330int 340exh, valve lift .680int/.695Exh lobe angle 110°
-need to redo-Cam bearings Dura-Bond
(GMP-12LT)High perf Coated Bearings $91.92
-Gasket set (MRG7106) $57.97
-Main Crank Bearings H-Series(Clems829H) $104.97
Heads GM 118cc 6272990
PPB Racing 10gal fuel tank
-Pushrods-competition cams intake 7932,exhaust 7979 9.350 .080
Build
-Crank bearing plastigaged clearance at .003 thousands
-Crank forward/back thrust gaged at
mike 805-340-5601
post-9043-0-70927200-1413165934_thumb.jp
post-9043-0-78950500-1413165952_thumb.jp
post-9043-0-94949100-1413165969_thumb.jp
post-9043-0-76908100-1413165993_thumb.jp
post-9043-0-24007100-1413166013_thumb.jp
post-9043-0-11944300-1413166033_thumb.jp
