2006 Desert Dynamics Buggy Works LS / 2D Alot Of Upgrades 5 seater NEW PRICE!
jwcarguy
Well the sad time has come to post our car up for sale, that has been great to us for almost 6 years!
We bought a new car/ chassis that we are building, so one has to go
2006 Desert Dynamics / Buggy Works 5 seater
When we bought it, it was newly built by Dan (mtrsportdan) and Shawn Jones (Jones Fab.) (vin and titled/ Cert of Origin as a 06' Desert Dynamics) Main chassis , arms is from Dave @ Desert Dynamics
Over this time, the car has undergone numerous changes and upgrades
- the main frame is only "Buggy Works" part original (chromoly 1 1/2" frame) narrower than fullsize DD sand car, but has over double the rear seat leg room as DD sandcar
- the suspension was upgraded to the 2.0x 10" shocks that include the new lower a-arms for the longer shocks, new upper arms were built same as lowers (1 1/2" chromoly)
- rear 2.5x16" bypasses added along side the 2.5 x 14" coil overs (Kings in pics not on car, have new shocks/ springs all around)
- addition of longer & wider rear trailing arms from a DD car
- rear cage was remade and now is removable and not the ugly squared off back
- added 1/4" aluminum full skid plate under engine and trans
Addition of V8 engine and Mendeola 2D trans axle:
- LQ 6.0L (approx 490hp), rebuilt short block (8 trips ago)
- #243 (LS6) cylinder heads w/ PRC .650" dual springs w/ tia. retainers
- Texas Speed 228R cam
- TSP .080" 7.400" pushrods
- GM LS2 HD timing set
- LS7 lifters w/ LS2 lifter trays
- LS6 intake w/ 36# injectors & ported/ polished throttle body
_ARP head bolts, Harmonic balancer bolt, header studs
- Melling #10295 oil pump w/ GM LS2/3 Corvette center sump oil pan with internal baffling
-GM #411 pcm with tune by Texas Speed
- truck accessory drive w/ modified p/s pump reservoir for Charlyn return line
- Doug Thorley headers
Trans:
-Deco case 2D with all Weddle gear stack and ring & pinion (fresh 0 miles, always serviced by RC Trans), G50 inputshaft
- Weddle offset bellhousing and IMI hi torque starter
-Stage 4 clutch w/ 6 puc disc, flywheel & pressure plate just resurfaced, new GM pilot bearing
-934 cv's w/ 300m axles, Dual cv boot setup
- Pro Am billet shifter
- 33 spline microstubs
Brakes:
- 4 piston Jamar brakes rear, front 2 piston Jamar brakes wide 5 hubs
- Char-Lyn Power steering w/ Howe HD steering rack
Body:
-all aluminum by Shawn Jones (Jones Fab), full dash and gauges, interior panels vinyl lined
-full rhino lined aluminum floor pan
-full 1/4" aluminum skid plate under engine and transaxle
-Rigid Industries 40" combo LED lightbar and Dually D2 LED pods
- Rugged radios car to car, 4 person intercom system w/ digital upgrade, includes 4 person oth headsets
- - front "+2" buckets and rear bench
- (2) Crow 5 point padded harnesses front, (3) Crow 4pt harnesses rear
- Led brake and running lights high mount
- large JAZ fuel cell w/ remote filler
- 8' lighted Buggy Whip
Cooling:
-Ron Davis radiator w/ twin 16" Spal fans in shroud
- SLP 160 degree thermostat
- all -20 AN stainless steel braided lines and fittings
Tires:
-full dirt tires (33" BFG & 33" Baja Pros on Centerline 15x7 rims )
-33' STU Blasters and 8.80 triple razors (tires only, no rims included)
car is located in Las Vegas
Asking $29,900 obo (no trades, thanks) 4/23/15 FIRE SALE!!! Need funds for house purchase now only $26,000 SOLD!!!
call/ text/ pm (702)677-4085
Thanks for looking, Jeff
post-3932-0-14799200-1425352690_thumb.jp
post-3932-0-62969500-1425352700_thumb.jp
post-3932-0-61915400-1425352713_thumb.jp
post-3932-0-15067900-1425352721_thumb.jp
post-3932-0-92023900-1425352730_thumb.jp
post-3932-0-97791100-1425352739_thumb.jp
post-3932-0-44853300-1425352750_thumb.jp
post-3932-0-30456000-1425352764_thumb.jp
post-3932-0-34233600-1425352777_thumb.jp
post-3932-0-21794900-1425352786_thumb.jp
post-3932-0-57558100-1425352795_thumb.jp
post-3932-0-51257600-1427125409_thumb.jp
post-3932-0-00017300-1427125420_thumb.jp
post-3932-0-14079000-1427125430_thumb.jp
post-3932-0-14082100-1427125446_thumb.jp
post-3932-0-48137400-1427125463_thumb.jp
post-3932-0-51661100-1427125476_thumb.jp
post-3932-0-29095100-1427125493_thumb.jp
post-3932-0-60113000-1427125500_thumb.jp
post-3932-0-51459400-1427125508_thumb.jp
post-3932-0-55728600-1427125519_thumb.jp
post-3932-0-39894800-1427125529_thumb.jp
Edited by jwcarguy
  • 1 month later...
  • 1 month later...
Someone got a great car at a great price. Congrats on the sale and enjoy your new house !
Thanks alot!
we are still looking for the house, but this will help with the new car build too!
