LQ 6.0L LS6 Top End, TSP Cam, Engine 490hp Package Feeler Ad ?
jwcarguy
I have someone that is looking at my 2006 DD/ Buggy Works car and has a engine already
so.... this is basically a feeler ad for the complete engine package w/ harness & tuned pcm, adapter plate, flywheel, clutch setup in my car, if the buyer buys it without engine
car ad: http://www.glamisdunes.com/invision/index....howtopic=322069
It only has approx 8 trips on this engine, yes it is a iron block engine (stronger and only 73 Llbs more than a aluminum block) difference of having alittle kid in the back seat as far as weight!
here are the specs. / details on it
- LQ iron 6.0L (approx 490hp), rebuilt short block std bore(8 trips ago)
- #243 (LS6) cylinder heads w/ PRC .650" dual springs w/ tia. retainers
- Texas Speed 228R cam
- TSP .080" 7.400" pushrods
- GM LS2 HD timing set
- LS7 lifters w/ LS2 lifter trays
- LS6 intake w/ 36# injectors & ported/ polished throttle body
_ARP head bolts, Harmonic balancer bolt, header studs
- Melling #10295 oil pump w/ GM LS2/3 Corvette center sump oil pan with internal baffling
-GM #411 pcm with tune by Texas Speed (approx hp @ crank, no dyno #'s)
- truck accessory drive w/ modified p/s pump reservoir for Charlyn return line
- Doug Thorley headers
- Gen III harness modified by S&S Performance as standalone setup
- CBM / K&N cone air filter with Outwears prefilter
- 90 degree mold intake hose
- Grantelli Performance Mass Air Flow Sensor
- AC Delco Corvette fuel regulator/ filter
also has adapter plate, just resurfaced flywheel, R&H Pressure plate fresh and new Kennedy clutch disc, new large GM pilot bearing 0 trips, just pulled into toyhauler
I attached a video of it at the bottom of ad, below pics
in Las Vegas
(702)677-4085
Jeff
post-3932-0-64248600-1430409172_thumb.jp
post-3932-0-01325400-1430409184_thumb.jp
post-3932-0-90474300-1430409236_thumb.jp
post-3932-0-18123000-1430409259_thumb.jp
post-3932-0-24315100-1430409279_thumb.jp
post-3932-0-34161700-1430409290_thumb.jp
post-3932-0-16751300-1430409304_thumb.jp
post-3932-0-63424200-1430409317_thumb.jp
