Welcome to DDR!
Sign In
Sign in to follow this
Jasmine
VW Mazzone Mid-engine, Mid-travel Sand rail VERY lightweight.
$17,000 OBO
Rebuilt VW Mazzone Mid-engine, Mid-travel Sand rail VERY lightweight.
1 trip (testing) after rebuild, Car is ready for 2017-18 Season
• Bernie Bergman 2.5L VW base engine, built for a turbocharger
• Custom Skat crankshaft
• Custom Engine block
• MSD ignition
• Pointless distributor
• Porsche Fan & shroud cooling
• Ported heads
• Mendeola MD-45 Transmission with 10" Pinion.
• Brentwood Nosecone & Cable shifter
• Fuel injection
• Turbonetic T-30 Turbocharger
• Custom exhaust
• 930 CV's.
• New Crow 4 point safety belts
• Tachometer
• Aircraft quad gauge, oil temp., oil pressure, CHT, volts
• Boost gauge
• Fox & King Shocks, 14" travel all corners, All rebuilt at RC Trans
• New Beard seats
• New paddles and rims with rim-locks
• Ribbed front tires with new rims
• Braded stainless steel hoses
• Complete front end re-design, including A-arms,
• 4 wheel disc brakes
• Turning brakes
• High pressure fuel pump & regulator
• New high flow off-road oil cooler
• New front spindles
• Oil sump
• Custom 7 gallon fuel tank
• Rack & Pinion steering
• Momo removable steering wheel
• Functional rear wing with oil cooler, oil breather, and storage
• Custom aluminum side panels, engine shroud, intake cooling fan shroud
• No Frame cracks
• Off road AGM battery
• Battery disconnect switch
• Battery tender plug
• LED whip and flag
• 35 mm / GoPro camera mount
• Extra parts, filters, fasteners, belts, etc.
• Testing rear tires mounted on Centerline rims
*** Located in Las Vegas***
Share this post
Link to post
  • image.gif?ctc=DDR
