Doghouse Posted May 12 Share Posted May 12 (edited) See it on our site with video :https://www.doghouserepair.com/store/item/15628/87393-2332cc-91-cr-91-or-better-octane-engine-for-sale/ 84 stroke crank 8 dowel with 10 mains 10 rods 5.5" aluminum rods web 86B camshaft 575" lift 300 duration 1.3:1 ratio aluminum roller tip rockers straight cut gears 10 over brazil / chevy rod bearings New aluminum standard block steel backed mains std Block 10 mains std thrust CB Perf 32mm geared oil pump 9104 pushrod tubes cyl shims .090" thick & .040" copper head spacers for 9:1 CR cb 044 super pro (67cc combustion chamber) heads dual spring 45 x 37.5 valves NOT TURBO READY 3177 matched manifolds by CB Perf Elring gasket kit 31-3011 fuel pump block off sand seal 4513 CB Perf chromoly flywheel big p/up tube welded in place deep sump & chrome drain plate w/ oe cap nuts Wolfsburg West silicone oil drain gaskets cylinder tins 9063 9138 v-cover set Compu-Fire coil power pulley belt Aluminum outer top pulley half 33-1040 NGK dp8ea-9 long reach spark plugs 48IDF's w/ 55 idles, 210 airs, F2 emulsions, 135 mains with notched v-stacks 60 amp alternator with chrome stand & strap custom aluminum pistons All new Total Seal rings (custom made top rings) chrome doghouse shroud Requires a good core (INQUIRE) No core? = $500 more Yes there's tax Inquire for shipping ESTIMATE EXHAUST IS FOR DISPLAY ONLY Edited Tuesday at 07:32 PM by Doghouse 1 Quote Link to comment Share on other sites More sharing options...
