Cleaning out garage misc parts
crewzin70
Up for grabs
T3T4 turbo, brand unknown, new never used. Was bought for a toyota pickup build but my buddy sold it and bought a Duramax
250.00
chrome subaru s tube, goes from t3t4 turbo to flipped intake manifold on a 2.5 DOHC when no intercooler is used.
25.00
Limiting straps, eyes are 8.5 apart
10.00ea
Used/ needs repair single piston CNC #623 caliper.Pressure hole needs to be oversized tapped,fitting was bumped for a while and eventually knocked out by bad hose routing.
10.00
CNC clutch or brake reservoir 3/4 bore, needs rebuild.
10.00
CNC slave cylinder one on right needs a rebuild
5.00 left is sold
Latest rage u-joint, 7/8 smooth for charlynn to 5/8 36 spline. still nice and tight.
20.00
22in long 930 axles, no problems, they were pulled and longer ones put in when my buddy did a tranny swap.
100.00
JE pistons and rings, barely used, came out of a 2.5 SOHC engine that was recently built and they decided to not run a turbo engine and swapped these out for stock pistons. I bought them not knowing they would not work in my DOHC build.
250.00
Supreme throttle cable (think its a morse), 9Ft used one season in perfect shape
35.00
Pm or text
Patrick
702 401 3666
Thanks for looking!
Edited by crewzin70
