Pablovent Posted September 12, 2021 Posted September 12, 2021 (edited) Hi There; What is the best option to install my new 13.00~15 rear paddle tires: 10" or 12" rims?? Thanks and my best.. Edited September 21, 2021 by Pablovent Quote
Pablovent Posted September 21, 2021 Author Posted September 21, 2021 HI There; I use 13.00-15" Stephen sandviper II paddle tires....picture rim Specs? Quote
IrnBear Posted October 8, 2021 Posted October 8, 2021 On 9/21/2021 at 5:43 AM, Pablovent said: HI There; I use 13.00-15" Stephen sandviper II paddle tires....picture rim Specs? Sorry taken so long to get back to you not sure how to spec so here are pics Tires are separating at the bead, so might take a little work to undo whatever glue job they did Make me an offer Quote
Sandrift3 Posted October 22, 2021 Posted October 22, 2021 To answer you question, a 12" rim will give you more grip and a 10" will give you more cush. You will drift more with a 12", I think there is more adjustability when dealing with grip with a 10". I use13.00x15 on 10"on 1300lb car with 280hp to the wheels and it grips at 10lb. But at the drags I run 7 to 8lb. Quote
