farfiqdunner Posted 1 hour ago Share Posted 1 hour ago This trailer was custom built by R.P. Industries of Pahrump. All rust shown is surface only and does not negatively impact the structure. The trailer was built for wide long travel sandrails. It features a Warn Winch System. It has a heavy duty single square bar toung when you need to maneuver in a tight spot. The bed is 8 foot wide by 12 feet in length. It can accomodate most long travel cars. It has an adjustable hitch to accomodate any hitch height. It has a hidden breaker bar and deep socket to fit all nuts except wheel lugs. The tounge jack is heavy duty and can lift 5000lb. If you get a flat on the trailer while towing no worries. Leave the sand car loaded and move the tounge jack to the rear. Then jack up the rear of the trailer remove the flat and put on the spare! So easy! Deck is made of heavy duty galvanized steel. Trailer has electric brakes and tire covers. The two axles are 3,500 lbs. Total load weight 7,000 lbs. The ramps are adjustable in width. So anything from a polaris single seat to the widest of long travel cars can be loaded. A very rare trailer to find. $3,000 (702) 505-2192 Quote Link to comment Share on other sites More sharing options...
