fuel station fuse?
evoorng
UGH OH.. Let me guess Weekend Warrior?
There is a fuse in the box near the entrance door. Same box as your converter. Or 12 volt kill switch
hear is my thought though... your gears may have swelled in your fuel pump.. once you change fuse I bet it blows again.. Hope not for you, but usually that is IT....
If its is, I'll go look up how to fix for you, if you are interested.. or you replace the pump......
Good luck
Mine is right by the 12 volt kill switch where you store the cord. It is the individual fuse outside the box of other fuses. I have a cr3705. In mine that fuse gets beat up from the cord so it has been replaced a few times.
i have a fuse panel next to my power cut off but nothing is marked so i dont know what fuse is what. prob 10-15 fuses but none of them are blown
I will try to get by my hauler today and take a pick of wich one it is in mine.
